[Gdal-dev] Enhancements to the DODS/OPeNDAP driver
James Gallagher jgallagher at gso.uri.edu
Wed Jan 21 18:46:32 EST 2004
I have completed some more work on the DODS/OPeNDAP driver. It can now
read portions of rasters using the DAP constraint expressions. This
means that only the parts of the raster actually requested by the
application will be read over the wire. The code is in CVS.
There are some further optimizations that are pretty obvious and I'll
work on those at time permits.
James
__________________________________________________________________________
James Gallagher		         The Distributed Oceanographic Data System
jgallagher at gso.uri.edu               http://unidata.ucar.edu/packages/dods
Voice/Fax: 406.723.8663
