[Gdal-dev] Enhancements to the DODS/OPeNDAP driver
James Gallagher jgallagher at gso.uri.edu
Fri Jan 23 10:57:38 EST 2004
On Wed, 2004-01-21 at 18:15, Norman Vine wrote:
> James Gallagher writes:
> > I have completed some more work on the DODS/OPeNDAP driver. It can now
> > read portions of rasters using the DAP constraint expressions. This
> > means that only the parts of the raster actually requested by the
> > application will be read over the wire. The code is in CVS.
> Nice :-)
> Has anyone got any tips on compiling DODS/OPeNDAP with Cygwin ?
At one point we were supporting this but decided instead to support MS
VC++. Since that works I'll be Cygwin will work too. You might look at
defining WIN32 when you build...
Let me know how it goes.
James
> Cheers
> Norman
> Gdal-dev mailing list
> Gdal-dev at remotesensing.org
> http://remotesensing.org/mailman/listinfo/gdal-dev
__________________________________________________________________________
James Gallagher		         The Distributed Oceanographic Data System
jgallagher at gso.uri.edu               http://unidata.ucar.edu/packages/dods
Voice/Fax: 406.723.8663
