[Gdal-dev] Build/ Compile problem
thisiseric at shaw.ca
Fri Jan 23 11:01:27 EST 2004
Good morning,
I am trying to get up and running with GDAL and durring my installation of 1.1.9 on Mandrake Linux 9.2. When I try to run the 'make all' the following error stops the install:
make[1]: Entering directory `/usr/software/Map Server/gdal-1.1.9/apps' gcc -I/usr/software/Map Server/gdal-1.1.9 -I/usr/software/Map Server/gdal-1.1.9/port -I/usr/software/Map Server/gdal-1.1.9/gcore -I/usr/software/Map Server/gdal-1.1.9/ogr -I/usr/software/Map Server/gdal-1.1.9/frmts -I/usr/software/Map Server/gdal-1.1.9/alg -c -Wall -fPIC -O2 gdalinfo.c -o gdalinfo.o
gcc: cannot specify -o with -c or -S and multiple compilations
make[1]: *** [gdalinfo.o] Error 1
make[1]: Leaving directory `/usr/software/Map Server/gdal-1.1.9/apps'
make: *** [apps-target] Error 2
Admiditly I am not an experienced Lnux user but we all have to start somewhere.
I thank you in advance for any help that you can provide me.
Eric W
