[Gdal-dev] Geotiff metadata conversion?
Norman Vine nhv at cape.com
Fri Jan 23 18:13:32 EST 2004
Don Tidrow writes:
> Is there a gdal utility/function(s) that will convert from the first format
> into the second, or is there simply not enough metadata in the first
> geotiff to convert it?
Don
If you have more projection info available as perhaps an auxillary
 metadata file it is fairly easy to insert that into the tiff file with geotifcp
HTH
Norman
