[Gdal-dev] Compositing warped images
Thu Jan 29 10:58:20 EST 2004
Robert Osfield wrote:
> I'll need to code something similar to RasterIOWithNoData() at my end, do you
> think it woul make sense to convert desitination line by line or to just
> convert the whole region at once.   I'm inclined to do a single RasterIO call
> and then copy and filter in one go across to the final destination.  Whats
> you thoughts on the tradeoffs on performance/memory usage.
> When I'm finished if I have something reusable I'll post it in.
Robert,
I would suggest doing a single RasterIO() call.  The more you can aggregate
your IO requests into single calls, the more opportunity GDAL has to do things
more efficiently.
Best regards,
