[Gdal-dev] MinGW & GDAL: "[Linker error] undefined reference..."
Jochen Krüger
kruegerj at gmx.de
Sun Jul 25 19:59:32 EDT 2004
Hello,
I'm trying to use the gdal libraries with MinGW (Dev-C++) - but even
after checking the respective threads in this newsgroup I can't get it
to work. This is most likely rooted in my lack of experience with C/C++
and/or the compilation and installation of libraries. I'm not a
professional programmer, just someone in need of a specific tool, with
no budget but enough enthusiasm to try it myself - so please bare with
me if the following seems trivial to you:
I need a working GCC library with HDF4 support for a tool essential for
one of my projects. I tried to use the binary that came with OpenEV and
also the one available from the gdal website, but with both I get the
following errors when compiling my programme:
"[Linker error] undefined reference to `GDALAllRegister'"
"[Linker error] undefined reference to `GDALOpen'"
Similar error messages are given for any instance where I use one of the
libraries instructions. I have configured the paths to the includes and
the library in Dev-C++ correctly, so I must assume that it's something
with the library I'm using or with the way I'm using it...
I tried to google for some answers, but all I could come up was to use
extern "C" {} around the include for gdal - but that didn't resolve it.
Neither did some hints about the absolute path work, as the library is
not in a seperate path of its own but directly in the compilers lib
folder. Others mentioned possible problems if the library was compiled
with a different version of the compiler (the MinGW version I'm using is
GCC 3.2). In that case I'm damned, as I already tried to compile the
library and failed completely - even with all the hints available in
this newsgroup. :(
Here's a part of my code, maybe one of you spots the problem, so I can
get this running:
-cut-
#include <iostream>
#include <stdlib.h>
#include <gdal_priv.h>
using namespace std;
GDALDataset *panDataset;
int main(int argc, char *argv[])
GDALAllRegister();
const char* pan_infile=argv[1];
// Open Pan
panDataset = (GDALDataset *) GDALOpen( pan_infile, GA_ReadOnly );
if( panDataset == NULL ) {
cout << endl << "Pan-Input kann nicht geoeffnet werden!" << endl;
errorvalue=2;
-cut-
