[Gdal-dev] 8-bit grayscale
Sanges Michele
Michele.Sanges at otomelara.it
Thu Jul 1 05:04:58 EDT 2004
Hi all,
I'm trying to develop an embedded application, which must have also the functionalities of a GIS. The application runs on Linux operating system (kernel 2.4.x, busybox filesystem); for the graphic side I use the Microwindows server (a small X server), and the GUI is writted by means the FLTK library. I successfully compiled and installed GDAL 1.2.0 on my system.
Now, some beginner questions:
- when the method GetColorInterpretation() returns "Undefined" (for example, the "/aig/dblbnd.adf" test file), in order to represent the dataset in an 8?bit grayscale, I used the following conversion:
int nRasterCnt = poDataset->GetRasterCount();
int nRasterXSize = poDataset->GetRasterXSize();
int nRasterYSize = poDataset->GetRasterYSize();
double adfMinMax[2];
int bGotMin, bGotMax;
adfMinMax[0]=poBand->GetMinimum(&bGotMin);
adfMinMax[1]=poBand->GetMaximum(&bGotMax);
poBand->RasterIO(GF_Read, 0, 0, nXSize, nYSize, pImageData, nXSize, nYSize, poBand->GetRasterDataType(), 0, 0 );
for (int nByte = 0; nByte < nRasterCnt*nRasterXSize*nRasterYSize; nByte++)
// convert in 0..255 range /(8?bit grayscale)
int nApp = (255 / (adfMinMax[1] - adfMinMax[0])) * (*(pImageData + nByte) - adfMinMax[0]);
if (nApp < 0)
nApp = 0;
else if (nApp > 255)
nApp = 255;
*(pData + nByte) = nApp;
Fl_RGB_Image * RGBImg = new Fl_RGB_Image((uchar*)(pData), nRasterXSize, nRasterYSize, poDataset->GetRasterCount());
Using this conversion, the dblbnd.adf file is represented too dark, probabily because the dataset has many low values.
I can solve this problem reducing the range of 8 bit grayscale to [N..255] (N > 0), but how do you generally converted the dataset?
- Somebody is using the FLTK graphic library?
Thanks.
Michele Sanges
