[Gdal-dev] Memory leaks
Roger James roger at beardandsandals.co.uk
Tue Jul 6 13:47:24 EDT 2004
The visual studio leak reporting function is notoriously inaccurate. It
reports any allocations made in any dll initialization called before the
main program is started as a leak.
Step into your program and then see what heap allocation number currently is
right at the start. It is held in a static _lRequestCur in the CRT library.
A watch on
{,,msvcr71d.dll}_lRequestCurr
usually works if you are using the debug DLL runtime.
Anything in the heap dump which is lower than this number is probably
erroneous.
Roger
> Jacob Bensabat wrote:
>  > Hi
>  > We are using gdal to load vector maps (format mif, shp) under windows
> 2000
>  > and visual c++ 6.0. What I see is that there is a large number of small
>  > memory leaks. Has anybody
>  > experienced such kind of feature ?
>  > thanks
