[Gdal-dev] Ogr2Ogr
Martin Hodder
mhodder at highermappingsolutions.com
Mon Jul 12 17:39:09 EDT 2004
I am new to this program but I am getting on OK.
I can specify ogr2ogr -f "MapInfo File" -dsco FORMAT=MIF C:\ogr\test.mif
test.tab and all works fine
But when I try ogr2ogr -f "ESRI Shapefile" C:\ogr\test.shp c:\ogr\test.mif
it does not work.
It fails with the following message:-
Error 4: Failed to open shapefile C:\ogrC:\ogr\test.shp.
Error 1: terminating translation.
Note I have correctly given the error message in Error 4! It does not like
path names. I can do in the same directory with path names and it works
fine. The directory exists and the MIF file contains only points.
Does any know what is happening?
Many thanks
Martin
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20040712/4fde8650/attachment.html
