[Gdal-dev] gdal config icluding xerces
    Daniel Isenegger
    disen at geo.unizh.ch
    Tue Jul 13 06:31:21 EDT 2004
Hi
after some problems with installing Xerces in default paths, i think i
overcome (with the patient help of Frank) this problems (now it seems
that gdal finds the Xerces libs and includes), at least i got a new
error message (:-)
checking for Xerces C++... requested, but compile or link fails!
./configure --with-grass=/usr/local/grass-5.7.0
--with-pg=/usr/local/pgsql/bin/pg_config --with-xerces
--with-odbc=/usr/local/lib --with-static-proj4=/usr/lib/libproj.so | tee
configure_disen.log
g++ -I/usr/local/include/xercesc -o conftest conftest.cpp
-L/usr/local/lib -lxerces-c -L/usr/local/grass-5.7.0
-L/usr/local/grass-5.7.0/lib -lgrass5 -lz -lm -ldl
/usr/lib/gcc-lib/i586-suse-linux/3.3.3/../../../../i586-suse-linux/bin/ld:
cannot find -lgrass5
collect2: ld returned 1 exit status
what i don't understand here:
is still Xerces causing the problem or is it grass
for info:
grass57 installed in /usr/local/grass-5.7.0 (as indicated in
config-statement)
Thanks Dani
Frank Warmerdam schrieb:
> Daniel Isenegger wrote:
>> Hi Frank,
>> thanks for for your advice. Unfortunately it still doesn't work. I
>> included your advices:
>> --with-xerces-inc=/usr/local/xerces-c-src2_2_0/include/xercesc
>> --with-xerces-lib="-L/usr/local/xerces-c-src2_2_0/lib -lxerces-c
>> -lpthread" --with-odbc=/usr/local/lib
>> --with-static-proj4=/usr/lib/libproj.so | tee configure_disen.log
> Daniel,
> In your earlier example you were using Xerces 2.1 but now you are showing
> 2.2 paths.  Did you build 2.2 as well in trying the new paths?  I used
> 2.2 in my examples because that is what I have installed.
>> the error is: cannot find files, e.g. file
>> xercesc/util/XercesDefs.hpp (which is at that location). Does gdal
>> search only the paths given in the configuration or also consider
>> environment vars?
> I am not aware of the makefiles or configure using environment vars for
> include file search paths.
>> g++ -I/usr/local/xerces-c-src2_2_0/include/xercesc
>> /usr/local/xerces-c-src2_2_0/include -o conftest conftest.cpp
>> -L/usr/local/xerces-c-src2_2_0/lib -lxerces-c -lpthread
>> -L/usr/local/grass-5.7.0 -L/usr/local/grass-5.7.0/lib -lgrass5 -lz
>> -lm -ldl
>> In file included from conftest.cpp:1:
>> /usr/local/xerces-c-src2_2_0/include/xercesc/util/PlatformUtils.hpp:65:39:
>> xercesc/util/XercesDefs.hpp: No such file or directory
> Hmm, there seems to be a conflict between how I refer to include files
> from xerces in my code (not including the xercesc prefix) and how they
> are referred to by Xerces code itself, including the xercesc prefix.
> This happens to work for me because due to stuff already having been
> pre-installed.
> I think you will need an include path that includes the xercesc directory
> and the directory above it.  This can't be easily controlled by configure
> options as things stand, so you will likely need to hand edit
> GDALmake.opt
> and change the XERCES_INCLUDE to look something like:
> XERCES_INCLUDE = -I/usr/local/xerces-c-src2_2_0/include/xercesc \
> I have altered the configure logic in CVS to include both locations and
> now the appropriate value to pass in --with-xerces-inc would be the
> directory *above* the xercesc directory.
>> if i understand you right, you suggest to just install
>> xerces-binaries at the default place and let gdal-config script look
>> for xerces?
>> My problem is, there are no xerces-binaries for suse9.1 and in the
>> binaries of former versions, there is no default installation path
>> suggested.
> I am suggesting building Xerces from source, and then doing a "make
> install".
> The default install location is under /usr/local and if this had been
> done
> everything would have worked on the first time.  I haven't done a very
> good
> job in explaining other options partly because behind the scenes the
> compiler was still finding the stuff under /usr/local even when I
> tried to
> force it to use a different copy.
>> if i have installed xerces as i have it now and just run the
>> gdal-config script with --with-xerces the same error as described in
>> the first mail occurs (conftest.cpp:1:34: util/PlatformUtils.hpp: No
>> such file or directory ).
> Well, currently you have a *build* tree under /usr/local, as opposed to
> having installed it (apparently).
> Boy, I just hate build problems on machines I don't have access too.
> It is
> so hard for me to deduce what can be going wrong through the narrow
> window
> of email bug reports.
> Best regards,
