[Gdal-dev] make error
Daniel Isenegger
disen at geo.unizh.ch
Wed Jul 14 06:19:41 EDT 2004
Hi
the configuring the way Frank suggested worked well:
./configure --with-pg=/usr/local/pgsql/bin/pg_config --with-xerces
--with-xerces-inc=/usr/local/include/xercesc
--with-xerces-lib="-L/usr/local/lib/libxerces-c.so.22.0 -lxerces-c
-lpthread" --with-odbc=/usr/local/lib
--with-static-proj4=/usr/lib/libproj.so | tee configure_disen.log
GDAL is now configured for i686-pc-linux-gnu
Installation directory: /usr/local
C compiler: gcc -O2
C++ compiler: g++ -O2
LIBTOOL support: yes
LIBZ support: external
GRASS support: no
CFITSIO support: no
NETCDF support: no
LIBPNG support: external
LIBTIFF support: external
LIBGEOTIFF support: internal
LIBJPEG support: external
LIBGIF support: internal
OGDI support: no
HDF4 support: no
JASPER support: yes (GeoJP2=no)
ECW support: no
MrSID support: no
POSTGRESQL support: yes
XERCES support: yes
ODBC support: yes
OCI support: no
DODS support: no
Statically link PROJ.4: yes
enable OGR building: yes
the following make statement failed then (the same thing with gmake)
make | tee makeOutput_disen.log
output:
/bin/sh ../libtool --mode=link g++ ogrinfo.o ../libgdal.la -o ogrinfo
g++ ogrinfo.o -o .libs/ogrinfo ../.libs/libgdal.so
-L/usr/lib/libproj.so/src /usr/lib/libproj.so -L/usr/local/lib
-L/usr/local/lib/lib -lodbc -L/usr/local/lib/libxerces-c.so.22.0
-lxerces-c -lpthread /usr/lib/libjasper.so /usr/lib/libjpeg.so -ltiff
-lpng -lz -ldl -L/usr/local/pgsql/lib -lpq /usr/lib/libstdc++.so
../.libs/libgdal.so: undefined reference to `GMLReader::PopState()'
`GMLReader::IsFeatureElement(char const*)'
`GMLReader::SetFeatureProperty(char const*, char const*)'
`GMLReader::IsAttributeElement(char const*)'
../.libs/libgdal.so: undefined reference to `GMLReader::PushFeature(char
const*, xercesc_2_2::Attributes const&)'
collect2: ld returned 1 exit status
make[1]: *** [ogrinfo] Error 1
make[1]: Leaving directory `/downloads/gdal-1.2.1/ogr'
make: *** [ogr-apps] Error 2
any ideas why?
thanks dani
