[Gdal-dev] Compiling ogr/gdal on win32 using MingW
Norman Vine
nhv at cape.com
Wed Jul 14 11:35:14 EDT 2004
Norman Vine writes:
> or do as I do and install a MingW tree inside of Cygwin
> i.e. I have established my MingW root at /usr/mingw
> and install mingw files under it
> then # mingw make doesn't understand Unix filenames
> % cp /bin/make.exe to /usr/mingw/bin
> and when I configure a MingW build I use
> ./configure --prefix=/usr/mingw --host=mingw32
OF course you need to insure that
Of course when using MingW like this you have to setup your path
appropriately too
i.e.
% export PATH="/usr/mingw/bin:$PATH"
HTH
Norman
