[Gdal-dev] OCI driver and views
Nicol Hermann
gdal at geoworld.de
Thu Jul 15 09:43:07 EDT 2004
Hi List,
i was wondering about the behaviour of the OGR/OCI driver. May be
someone can shed any light on that.
When i do a:
ogrinfo OCI:<user>/<pass>@oracle -so -sql 'select * from water'
I get back the summary of the table 'water' but i also get back error
messages form some objects
e.g.
ERROR 1: ORA-04043: Objekt VW_STAND ist nicht vorhanden
in OCIDescribeAny
I assume that the OCI driver could not handle views because all the
objects identified as errors are views which are registered in the
sdo_geom_metadata_table. Is that true?
How can i avoid the error messages in the output which refers to tables
i am not interested in?
I'am using gdal 1.2.0 on a debian 3.0r2 box.
Thanks for any help
Nicol
