[Gdal-dev] OGR code examples
Woon Wei Lee wlwoon at must.edu.my
Thu Jul 15 14:11:48 EDT 2004
Michele
If you're just starting out with OGR, it might be worth your time to try out the python bindings. I found the python interface to be loads easier to start with due to its interactive nature (for eg, you get instant feedback on every command you issue, automatic type instantiation, etc).
However, because it uses the same underlying classes as the C++ library, migrating over to C++ (or the C API) later on is much easier. Alternatively, you might find that the python bindings achieve all that you'd set out to do anyway! ;-)
Cheers
Wei Lee
On Wed, 14 Jul 2004 14:35:40 -0600
"Chapman, Martin" <MChapman at sanz.com> wrote:
> Michele,
> Check out the code below.  It will give you the basic idea of how to get
> geometries and features from ogr:
> COgrShapeLayer* COgrDataSource::ExecuteSQL(string sStatement,
> CSXBasicGeometry* pSpatialFilter,
> string sDialect)
> 	try
> 		if (!m_pDatasource)
> 			throw "Invalid data source null in
> COgrDataSource::ExecuteSQL().";
> 		OGRSpatialReference* pSpatialRef =
> m_pDatasource->GetLayer(0)->GetSpatialRef();
> 		OGRLinearRing* pRing = NULL;
> 		if (dynamic_cast< CSXPolygon*>(pSpatialFilter))
> 			CSXPolygon* pPolygon = (CSXPolygon*)
> pSpatialFilter;
> 			pRing = new OGRLinearRing();
> 			vector< double>::iterator it;
> 			vector< double>* pPoints =
> pPolygon->GetPoints();
> 			double nX = 0.0, nY = 0.0;
> 			for (it = pPoints->begin(); it !=
> pPoints->end(); it++)
> 				nY = *it;
> 				it++;
> 				nX = *it;
> 				pRing->addPoint(nX, nY);
> 			pRing->addPoint(pPoints->at(1), pPoints->at(0));
> 		else
> 			throw "Invalid spatial reference data type in
> 		OGRPolygon* pPolygon = new OGRPolygon();
> 		if (pSpatialRef)
> pPolygon->assignSpatialReference(pSpatialRef);
> 		pPolygon->addRingDirectly(pRing);
> 		OGRLayer* pLayer = m_pDatasource->ExecuteSQL((const
> char*) sStatement.c_str(),
> pPolygon,
> (const char*) sDialect.c_str());
> 		if (pLayer == NULL) throw (char*) CPLGetLastErrorMsg();
> 		COgrShapeLayer* pShapeLayer = CreateShapeLayer(pLayer);
> 		m_pDatasource->ReleaseResultSet(pLayer);
> 		if (CPLGetLastErrorNo() != OGRERR_NONE) throw (char*)
> 		return pShapeLayer;
> 	catch(exception e)
> 		{throw e;}
> 	catch(char* e)
> 		{throw e;}
> 	catch(...)
> 		{throw "An unexpected error occurred in
> COgrDataSource::ExecuteSQL().";}
> CSXFeatureTable* COgrDataSource::CreateFeatureTable(OGRLayer* pOgrLayer)
> 	try
> 		if (!pOgrLayer)
> 			throw "Invalid parameter null in
> COgrDataSource::CreateFeatureTable().";
> 		OGRFeatureDefn* pFeatureDefn =
> pOgrLayer->GetLayerDefn();
> 		int nFieldCount = pFeatureDefn->GetFieldCount();
> 		const char* pszLayerName = (char*)
> pFeatureDefn->GetName();
> 		CSXFeatureTable* pFeatureTable = new
> CSXFeatureTable(pszLayerName, nFieldCount + 1);
> 		pFeatureTable->SetColumnName(0, "FID");
> 		pFeatureTable->SetType(0, DBF_TYPE_NUMERIC);
> 		pFeatureTable->SetLength(0, 4);
> 		pFeatureTable->SetDecimalCount(0, 0);
> 		for (int i = 0; i < nFieldCount; i++)
> 			OGRFieldDefn* pFieldDefn =
> pFeatureDefn->GetFieldDefn(i);
> 			const char* pszNameRef =
> pFieldDefn->GetNameRef();
> 			unsigned char cDataType =
> GetShapeDataType(pFieldDefn->GetType());
> 			unsigned char cWidth = (unsigned char)
> pFieldDefn->GetWidth();
> 			unsigned char cPrecision = (unsigned char)
> pFieldDefn->GetPrecision();
> 			pFeatureTable->SetColumnName(i + 1, pszNameRef);
> 			pFeatureTable->SetType(i + 1, cDataType);
> 			pFeatureTable->SetLength(i + 1, cWidth);
> 			pFeatureTable->SetDecimalCount(i + 1,
> cPrecision);
> 		OGRFeature* pOgrFeature = pOgrLayer->GetNextFeature();
> 		while (pOgrFeature)
> 			vector< string>* pRecord = new vector< string>;
> 			char pszBuffer [sizeof(long) * 8 + 1];
>             sprintf(pszBuffer, "%d", pOgrFeature->GetFID());
> 			pRecord->push_back(pszBuffer);
> 			for (long j = 0; j < nFieldCount; j++)
> pRecord->push_back(pOgrFeature->GetFieldAsString(j));
> 			pFeatureTable->AddRecord(pRecord);
> 			delete pOgrFeature;
> 		pOgrLayer->ResetReading();
> 		return pFeatureTable;
> 	catch(exception e)
> 		{throw e;}
> 	catch(char* e)
> 		{throw e;}
> 	catch(...)
> COgrDataSource::CreateFeatureTable().";}
> COgrGraphicList* COgrDataSource::GetPointGeometry(OGRLayer* pOgrLayer,
> CSXDrawingAttributes* pDrawingAttributes)
> 	try
> 		if (!pOgrLayer || !pDrawingAttributes)
> COgrDataSource::GetPointGeometry().";
> 		double nLat, nLon;
> 		CSXGraphic* pSXPoint = NULL;
> 		OGRPoint* pOgrPoint = NULL;
> 		vector< float> vXYPoint;
> 		COgrGraphicList* pList = new COgrPointList();
> 		OGRFeature* pFeature = pOgrLayer->GetNextFeature();
> 		while (pFeature != NULL)
> 			OGRGeometry* pGeometry =
> pFeature->GetGeometryRef();
> 			if (!pGeometry) continue;
> 			pOgrPoint = (OGRPoint*) pGeometry;
> 			long nFID = pFeature->GetFID();
> 			int nShapeType = (int)
> pGeometry->getGeometryType();
> 			if (nShapeType == SHAPE_TYPE_NULL)
> 				continue;
> 			nLon = pOgrPoint->getX();
> 			nLat = pOgrPoint->getY();
> 			pSXPoint = new COgrPoint(nLat, nLon);
> 			pSXPoint->SetAppObject((unsigned int) nFID);
> 			pDrawingAttributes->SetTo((CSXGraphic*)
> pSXPoint);
> 			pList->Add(pSXPoint);
> 		return pList;
> 	catch(exception e)
> 		{throw e;}
> 	catch(char* e)
> 		{throw e;}
> 	catch(...)
> COgrDataSource::GetPointGeometry().";}
> COgrGraphicList* COgrDataSource::GetPolyGeometry(OGRLayer* pOgrLayer,
> CSXDrawingAttributes* pDrawingAttributes, int nShapeType)
> 	try
> COgrDataSource::GetPolyGeometry().";
> 		COgrGraphicList* pList = NULL;
> 		OGREnvelope pEnvelope;
> 		if (nShapeType == SHAPE_TYPE_POLYLINE)
> 			pList = new COgrPolyLineList();
> 		else if (nShapeType == SHAPE_TYPE_POLYGON)
> 			pList = new COgrPolygonList();
> 			if (!pGeometry)
> 				continue;
> 			int nShapeType = SHAPE_TYPE_NULL;
> 			int nGeomType = pGeometry->getGeometryType();
> 			if (nGeomType == wkbUnknown)
> 				continue;
> 			else if (nGeomType == wkbLineString || nGeomType
> == wkbMultiLineString)
> 				nShapeType = SHAPE_TYPE_POLYLINE;
> 			else if (nGeomType == wkbPolygon || nGeomType ==
> wkbMultiPolygon)
> 				nShapeType = SHAPE_TYPE_POLYGON;
> 			long nVertexCount = 0;
> 			int nPartCount = 1;
> 			if (nGeomType == wkbLineString)
> 				nPartCount = 1;
> 			else if (nGeomType == wkbMultiLineString)
> 				nPartCount = ((OGRMultiLineString*)
> pGeometry)->getNumGeometries();
> 			else if (nGeomType == wkbPolygon)
> 				nPartCount =
> ((OGRPolygon*)pGeometry)->getNumInteriorRings() + 1;
> 			else if (nGeomType == wkbMultiPolygon)
> 				nPartCount = ((OGRMultiPolygon*)
> 			CSXGraphic* pPolygon = NULL;
> 			COgrGraphicList* pSubList = NULL;
> 			if (nPartCount > 1)
> 					pSubList = new
> COgrPolyLineList();
> SHAPE_TYPE_POLYGON)
> 					pSubList = new
> COgrPolygonList();
> 			for (long j = 0; j < nPartCount; j++)
> 				vector< double>* pPoints = new vector<
> double>;
> 						OGRLineString*
> pLinearString = (OGRLineString*) pGeometry;
> 						nVertexCount =
> pLinearString->getNumPoints();
> 						for (int n = 0; n <
> nVertexCount; n++)
> 							double nLambda =
> pLinearString->getX(n);
> 							double nPhi =
> pLinearString->getY(n);
> pPoints->push_back((double) nPhi);
> pPoints->push_back((double) nLambda);
> wkbMultiLineString)
> 						OGRMultiLineString*
> pMultiLineString = (OGRMultiLineString*) pGeometry;
> 						OGRLineString*
> pLinearString = (OGRLineString*) pMultiLineString->getGeometryRef(j);
> 						nVertexCount =
> 						for (int n = 0; n <
> nVertexCount; n++)
> 							double nLambda =
> 							double nPhi =
> SHAPE_TYPE_POLYGON)
> 						OGRLinearRing*
> pLinearRing = NULL;
> 						if (j == 0)
> 							pLinearRing =
> ((OGRPolygon*)pGeometry)->getExteriorRing();
> 						else
> 							pLinearRing =
> ((OGRPolygon*)pGeometry)->getInteriorRing(j - 1);
> 						nVertexCount =
> pLinearRing->getNumPoints();
> 						for (int n = 0; n <
> nVertexCount; n++)
> 							double nLambda =
> pLinearRing->getX(n);
> 							double nPhi =
> pLinearRing->getY(n);
> 							//if (nFID ==
> 1240)
> 								//cout
> << "Lat: " << nPhi << " Lon: " << nLambda << endl;
> wkbMultiPolygon)
> 						OGRLinearRing*
> pLinearRing = NULL;
> 						OGRMultiPolygon*
> pMultiPolygon = (OGRMultiPolygon*) pGeometry;
> 						OGRPolygon* pOGRPolygon
> = (OGRPolygon*) pMultiPolygon->getGeometryRef(j);
> 						if (j == 0)
> 							pLinearRing =
> pOGRPolygon->getExteriorRing();
> 						else
> 							pLinearRing =
> pOGRPolygon->getInteriorRing(j - 1);
> 						nVertexCount =
> 						for (int n = 0; n <
> nVertexCount; n++)
> 							double nLambda =
> 							double nPhi =
> 					pPolygon = new
> COgrPolyLine(pPoints, DECIMAL_DEGREES, LINETYPE_STRAIGHT);
> SHAPE_TYPE_POLYGON)
> 					pPolygon = new
> COgrPolygon(pPoints, DECIMAL_DEGREES, LINETYPE_STRAIGHT);
> 				pPolygon->SetAppObject((unsigned int)
> nFID);
> 				pPolygon->SetAppObjectPart((int) j);
> 				if (pDrawingAttributes != NULL)
> pDrawingAttributes->SetTo((CSXGraphic*) pPolygon);
> 				if
> (dynamic_cast<COgrPolyLine*>(pPolygon))
> 					CSXColor clear(0.0f, 0.0f, 0.0f,
> 0.0f);
> 					pPolygon->SetFillColor(&clear);
> 				if (pSubList != NULL)
> pSubList->AddSXGraphic(pPolygon);
> 				pGeometry->getEnvelope(&pEnvelope);
> 				vector< double>* pExtents = new vector<
> double>;
> 				pExtents->push_back((double)
> pEnvelope.MinY);
> pEnvelope.MinX);
> pEnvelope.MaxY);
> pEnvelope.MaxX);
> 				pSubList->SetExtents(pExtents);
> 				pSubList->SetAppObject((unsigned int)
> nFID);
> 				pList->Add(pSubList);
> 			else
> 				pList->Add(pPolygon);
> 		return pList;
> 	catch(exception e)
> 		{throw e;}
> 	catch(char* e)
> 		{throw e;}
> 	catch(...)
> COgrDataSource::GetPolyGeometry().";}
> If you have questions let me know.
> Martin
> -----Original Message-----
> From: Frank Warmerdam [mailto:warmerdam at pobox.com]
> Sent: Wednesday, July 14, 2004 2:30 PM
> To: Sanges Michele
> Cc: gdal-dev at xserve.flids.com
> Subject: Re: [Gdal-dev] OGR code examples
> Sanges Michele wrote:
> > Are there some code examples of how reading data files by means the
> > OGR library, in C++? Thanks.
> Hi,
> I am not aware of C++ examples other than the utility programs like
> ogrinfo.cpp and ogr2ogr.cpp.
> Best regards,
> I set the clouds in motion - turn up   | Frank Warmerdam,
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush    | Geospatial Programmer for Rent
> Gdal-dev mailing list
> Gdal-dev at xserve.flids.com
> http://xserve.flids.com/mailman/listinfo/gdal-dev
