[Gdal-dev] Kakadu Driver Dynamic Creation
Frank Warmerdam
warmerdam at pobox.com
Fri Jul 16 10:05:58 EDT 2004
Julien Demaria wrote:
> Hi,
> I need dynamic creation for the Kakadu driver...
> Are there any plans to implement it, or any existing contributions which
> partially implement this ?
> I don't know exactly if this is a complex or easy work and the time
> required to implement this...
> (I've rapidly walked on the driver code and this doesn't seam very
> hard... but maybe I'm wrong ? I think the createcopy method code seams
> to be a good starting point...)
> Thanks in advance (all advices are welcome),
Julien,
As far as I know, it is not possible to do proper dynamic creation of
JPEG2000 files via Kakadu. Basically, the data needs to be written scanline
by scanline - something which a dynamically created file can't ensure will
happen.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
