[Gdal-dev] Python USGS ASCII DEM
Norman Barker
normanb at comsine.co.uk
Mon Jul 26 14:43:47 EDT 2004
We are writing an GDAL program using the python wrappers and everything
is going well (the wrappers
around GDAL are really cool!).
I am having problems with a bottleneck with the USGS ASCII DEMs that we
are using. I understand from
http://www.remotesensing.org/gdal/frmt_usgsdem.html that they are
treated as one tile and are thus loaded in
completely.
The line we are using is
dem_src_data = dem_band.ReadAsArray(0, (start_row + iY) ,
src_tif.RasterXSize, 1)
so we are trying to read a section as long as the input tif file from
the DEM. The DEMS are over 100mb.
All the other code is very fast thanks to GDAL, but is there a work
around for this bottle neck?
Many thanks,
Norman
Norman Barker
Software Engineer
ComSine Ltd
Tel: +44 (0)1483 457121
Web: http://www.comsine.com
*Please Note:*
This text is confidential. If you are not the named addressee, it could be unlawful for you to read, copy, distribute, disclose or use the information contained herewith. If you are not the intended recipient please telephone +44(0)1483 457121.
