[Gdal-dev] processing SRTM-3?
Frank Warmerdam
warmerdam at pobox.com
Wed Jul 28 15:05:20 EDT 2004
Thom DeCarlo wrote:
> Oops, found another... issue. The SRTM documentation states that the NODATA
> value is -32768 and the shell script accommodates that by setting the
> appropriate value in the header file. However, it appears that the rest of
> the gdal software assumes that the NODATA value is -9999. Is there any way
> to tell the gdal_translate program to change any NODATA values it encounters
> to be -9999?
Thom,
The GDAL libraries should not assume a nodata value of -9999. The data is
being imported via the ESRI BIL format, right? What does the .hdr file have
for a NODATA value? What does gdalinfo report about a dataset?
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
