[Gdal-dev] processing SRTM-3?
Wed Jul 28 16:29:50 EDT 2004
Thom DeCarlo wrote:
> Frank Warmerdam wrote:
>>Thom,
>>Sometime relatively recently a hack was put into the GDAL GTiff driver to
>>save a nodata valuei in a GDAL-custom tag in the TIFF file.  It isn't
>>likely
>>that any non-GDAL application will recognise the nodata value in the TIFF
>>file.
>>Best regards,
> Ok, then I still need to find a way to change the values in the data from
> the current -32768 to the default value of -9999. Any ideas?
Thom,
Take a look at gdal/pymod/samples/val_repl.py.  It should do what you want I
think.
Best regards,
