[Gdal-dev] VRT Raw File Access
Frank Warmerdam
warmerdam at pobox.com
Fri Jul 30 17:58:45 EDT 2004
Folks,
At the request of Atlantis I have implemented support for accessing raw
raster file based on writing a VRT (XML) header file. This has some advantages
over existing ascii header formats support (such as PCI .aux, ENVI and ESRI BIL)
that include:
o The virtual dataset can include data from a variety of files.
o A variety of packing orders are supported, including different swapping,
and odd spaces.
o All GDAL supported pixel types are supported including complex.
o The VRT file can include any amount of supporting information such as
metadata, georeferencing, etc.
I have committed an initial implementation but I haven't really done too much
testing (though a small test script is in gdalautotest/gdrivers/vrtrawlink.py).
I have not updated any of the documentation accordingly yet. However, to give
you a flavour, here is a .vrt file making 4 raw Convair PolGASP data files
appear to be a single dataset.
<VRTDataset rasterXSize="1172" rasterYSize="1864">
<VRTRasterBand dataType="CFloat32" band="1" subClass="VRTRawRasterBand">
<SourceFilename relativetoVRT="1">l2p3hhsso.img</SourceFilename>
<ImageOffset>0</ImageOffset>
<PixelOffset>8</PixelOffset>
<LineOffset>9376</LineOffset>
<ByteOrder>MSB</ByteOrder>
</VRTRasterBand>
<VRTRasterBand dataType="CFloat32" band="2" subClass="VRTRawRasterBand">
<SourceFilename relativetoVRT="1">l2p3hvsso.img</SourceFilename>
</VRTRasterBand>
<VRTRasterBand dataType="CFloat32" band="3" subClass="VRTRawRasterBand">
<SourceFilename relativetoVRT="1">l2p3vhsso.img</SourceFilename>
</VRTRasterBand>
<VRTRasterBand dataType="CFloat32" band="4" subClass="VRTRawRasterBand">
<SourceFilename relativetoVRT="1">l2p3vvsso.img</SourceFilename>
</VRTRasterBand>
</VRTDataset>
I would add that we hope to update the OpenEV "raw define" tool to use .vrt so
that we can support all pixel types.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
