[Gdal-dev] Corrupted WKT in my GeoTIFF dem
Michael Logan
mlogan at mail.arc.nasa.gov
Fri Jul 30 18:45:36 EDT 2004
Frank Warmerdam wrote:
> Michael Logan wrote:
>> Hello,
>> I am trying to create a Geotiff DEM from scratch during conversion
>> from GridFloat format (i've tried multple formats (int16,float32,byte)),
>> but while everything seems good, the WKT is always clobbered.
>> I set the WKT in my C++ code, but after closing the file and exiting,
>> a gdalinfo gives "badness" for the projection portion:
>> % gdalinfo area79.tiff
>> Driver: GTiff/GeoTIFF
>> Size is 21600, 7200
>> Coordinate System is `'
>> Corner Coordinates:
>> Upper Left ( 0.0, 0.0)
>> Lower Left ( 0.0, 7200.0)
>> Upper Right (21600.0, 0.0)
>> Lower Right (21600.0, 7200.0)
>> Center (10800.0, 3600.0)
>> Band 1 Block=21600x1 Type=Int16, ColorInterp=Gray
>> So, my corners don't appear as Geographics corners
>> as I'd hoped, since it appears no info is available
>> to do the transform..
> Michael,
> Do you set a geotransform? Are you sure you are closing the file
> properly?
> What version of GDAL are you using? Can you provide a small but complete
> example program that demonstrates your problem?
> I see two likely issues:
> o If you don't close the file properly, the header info likely won't
> be written
> properly.
I am doing a GDALClose() just before exiting.
> o If you just write a coordinate system but no geotransform, I don't
> think any
> of the geotiff info gets written out.
Ok, this is might be it.. I didn't give the dataset ANY geotransforms.
I'm still not clear on how to use it and how it relates to the
Projection WKT.
I want a Geographic/unprojected GeoTIFF dem, so it seems
I need to read some more.. 8-)
thanks,
ml
> Best regards,
Michael Logan (650)-604-4494 QSS Group,Inc./NASA Ames Research Center
Task Lead, Visual Cueing & Simulation
Task Lead, Dynamic Aircraft Reconfiguration & Damage Adaptive Control
MS 262-6,Moffett Field, CA, 94035
private: logan5 at comcast.net
