[Gdal-dev] append option in ogr2ogr
Hans Verlouw
Hans.Verlouw at Geodan.nl
Wed Jun 2 05:16:58 EDT 2004
Hi list,
I noticed some strange behaviour when using the 'append' option of ogr2ogr.
I have twelve 2-dimensional ESRI shape files that I want to convert to one
single table in Oracle Spatial 9i.
When I convert one shape file and explicitly specify the -lco DIM=2 option,
the result is OK, so SDO_GTYPE = 2007 for all records.
But after I append other shape files (which are 2D originally too) the
resulting Oracle table gets over 90% records that are 3D,
so with SDO_GTYPE = 3007
For every step I specify the -lco DIM=2 option.
Am I doing something wrong here?
I also use the OVERWRITE=YES flag, but I don't think this is the problem,
because the table is growing at every step.
A snippet of my batch file:
ogr2ogr -f OCI OCI:%USER%/%PASS%@%DB%
%DATA%\Flevoland_tblEdugis_ObjRecht_region.shp -lco
SRID=90112 -lco DIM=2 -lco LAUNDER=YES -lco OVERWRITE=YES -nlt MULTIPOLYGON
-nln objrecht
ogr2ogr -append -f OCI OCI:%USER%/%PASS%@%DB%
%DATA%\Zeeland_tblEdugis_ObjRecht_region.shp -lco
-nln objrecht
%DATA%\Drenthe_tblEdugis_ObjRecht_region.shp -lco
-nln objrecht
%DATA%\Friesland_tblEdugis_ObjRecht_region.shp -lco
-nln objrecht
Thanks in advance,
Hans
Met vriendelijke groeten,
Hans Verlouw
Geodan IT b.v.
Buitenhaven 27-A
5211 TP 's-Hertogenbosch (NL)
Tel: +31 (0)73 - 692 5151
Fax: +31 (0)20 - 5711 333
Postadres / mailing address
President Kennedylaan 1
1079 MB Amsterdam (NL)
E-mail: Hans.Verlouw at Geodan.nl
Website: www.geodan.nl
Disclaimer: www.geodan.nl/disclaimer
