[Gdal-dev] Problems with writing RasterIO on WinXP
Wed Jun 2 16:37:12 EDT 2004
> float *analyseBuffer(float *hrBuffer, float *lrBuffer, int bsize) {
>     float *fuBuffer;
>     fuBuffer = (float *) CPLMalloc(sizeof(float)*bsize);
>     int i=1;
>     while (i <= bsize) {
>         fuBuffer[i]=(hrBuffer[i] + hrBuffer[i] + lrBuffer[i]) / 3;
>         i += 1;
>     return fuBuffer;
Jochen,
I noticed a couple of things.  Your loop above should be from i=0 to bsize-1
but you are looping from 1 to bsize which will write one word past the end
of the buffer potentially corrupting the heap.  Heap corruption has
unpredictable effects.  It might not break anything on one run, and crap out
on another run.
The other thing is that you aren't closing the files.  You should explicitly
"delete fusionDataset" at the end to get things flushed and closed properly.
Ahh heap corruption, the C/C++ programmers eternal pain.
Best regards,
