[Gdal-dev] Elevation Units in DEM or DTED files
Frank Warmerdam
warmerdam at pobox.com
Fri Jun 4 17:29:01 EDT 2004
Gerald Brandt wrote:
> Hi,
> Is there a way using GDAL where I can find out the units used for
> measurements. For example, is the elevation in feet or in meters? I
> looked at the projection text and couldn't find anything.
Gerald,
Call GetUnitType() on a GDALRasterBand and it will return either "m" or "ft"
indicating the pixel values are elevations in meters or feet. Defaults to
meters even for non-elevation products. It does return ft for some USGS DEM,
and SDTS dem products. Not sure about USGS DEM.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
