[Gdal-dev] Elevation Units in DEM or DTED files
Gerald Brandt
gbr at MICROPILOT.com
Fri Jun 4 17:38:03 EDT 2004
Thanks again. This one I should have been able to find myself... Doh!
Gerald
> -----Original Message-----
> From: gdal-dev-admin at remotesensing.org
> [mailto:gdal-dev-admin at remotesensing.org] On Behalf Of Frank Warmerdam
> Sent: Friday, June 04, 2004 4:29 PM
> To: gdal-dev at remotesensing.org
> Subject: Re: [Gdal-dev] Elevation Units in DEM or DTED files
> Gerald Brandt wrote:
> > Hi,
> > Is there a way using GDAL where I can find out the units used for
> > measurements. For example, is the elevation in feet or in
> meters? I
> > looked at the projection text and couldn't find anything.
> Gerald,
> Call GetUnitType() on a GDALRasterBand and it will return
> either "m" or "ft" indicating the pixel values are elevations
> in meters or feet. Defaults to meters even for non-elevation
> products. It does return ft for some USGS DEM, and SDTS dem
> products. Not sure about USGS DEM.
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam,
> warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | Geospatial
> Programmer for Rent
> Gdal-dev mailing list
> Gdal-dev at remotesensing.org
> http://remotesensing.org/mailman/listinfo/gdal> -dev
