[Gdal-dev] reprojection
Maciek Sieczka
werchowyna at pf.pl
Tue Jun 22 18:41:26 EDT 2004
Hi!
I got a following GTiff from an SRTM bil file:
Driver: GTiff/GeoTIFF
Size is 1201, 1201
Coordinate System is:
GEOGCS["WGS 84",
DATUM["WGS_1984",
SPHEROID["WGS 84",6378137,298.2572235630016,
AUTHORITY["EPSG","7030"]],
AUTHORITY["EPSG","6326"]],
PRIMEM["Greenwich",0],
UNIT["degree (supplier to define representation)",0.01745329251994328],
AUTHORITY["EPSG","4326"]]
Origin = (14.999583,51.000417)
Pixel Size = (0.00083333,-0.00083333)
Corner Coordinates:
Upper Left ( 14.9995833, 51.0004167) ( 14d59'58.50"E, 51d 0'1.50"N)
Lower Left ( 14.9995833, 49.9995833) ( 14d59'58.50"E, 49d59'58.50"N)
Upper Right ( 16.0004167, 51.0004167) ( 16d 0'1.50"E, 51d 0'1.50"N)
Lower Right ( 16.0004167, 49.9995833) ( 16d 0'1.50"E, 49d59'58.50"N)
Center ( 15.5000000, 50.5000000) ( 15d30'0.00"E, 50d30'0.00"N)
Band 1 Block=1201x3 Type=Int16, ColorInterp=Gray
Next I converted it into an "ETRS89 / Poland CS92" and then back into
GEOGCS.
Now the pixel size and the corner and centre coords are different:
Pixel Size = (0.00085946,-0.00085946)
Corner Coordinates:
Upper Left ( 14.9142554, 51.0303873) ( 14d54'51.32"E, 51d 1'49.39"N)
Lower Left ( 14.9142554, 49.9698135) ( 14d54'51.32"E, 49d58'11.33"N)
Upper Right ( 16.0633536, 51.0303873) ( 16d 3'48.07"E, 51d 1'49.39"N)
Lower Right ( 16.0633536, 49.9698135) ( 16d 3'48.07"E, 49d58'11.33"N)
Center ( 15.4888045, 50.5001004) ( 15d29'19.70"E, 50d30'0.36"N)
Band 1 Block=1337x3 Type=Int16, ColorInterp=Gray
I suspect that the answer is no (and that my question may be stupid) but I
want to know for sure: does it have to be like this or is there a way to
derive the genuine raster from a raster it was once reprojected to? Or to
improve the accuarcy at least?
Maciek
