[Gdal-dev] GDAL 1.2.1 Released
Mladen Turk
mturk at apache.org
Thu Jun 24 11:30:47 EDT 2004
Frank,
> From: Frank Warmerdam
> It can be avoided by building GDAL and the application with a runtime
> C library. I think this is accomplished with the /MD switch.
True, but MFC still has a separate heap so the same problem again :(.
> The other approach is to provide some sort of external destructor access
> via exact function entry points. I have done this already for many GDAL
> and
> OGR objects. In particular for GDAL it is usually sufficient to call
> GDALClose()
> on a dataset handle to clean things up.
Perhaps adding some tin root 'Object' for each public API class, like:
class OGRObject {
public:
OGRObject() {};
virual void Destroy(OGRObject *o) = 0;
Then you can have:
class OGRLayer : public OGRObject ...
and,
void OGRLayer::Destroy(OGRObject *o)
delete (OGRLayer *)o;
That will force that each inherited class implements the Destroy method.
> I would like to also rewrite the MapServer mapogr.cpp code to use
> the
> OGR C API instead of the C++ API.
Excellent (after all mapserver is all plain C).
MT.
Type: application/x-pkcs7-signature
Desc: not available
Url : http://lists.osgeo.org/pipermail/gdal-dev/attachments/20040624/17875a96/smime.bin
