[Gdal-dev] hdf4, hdf-eos and gcc 3.4 issues
Vincent Schut
schut at sarvision.com
Fri Jun 25 04:16:46 EDT 2004
On Thursday 24 June 2004 14:41, Norman Vine wrote:
<snip>
> I believe the attached HDFEOSVersion.h should work
Indeed, builds fine with this HDFEOSVersion.h
> BTW It would help if you told us what system you are using
> as well as the compiler
Sorry, thought I did that. Must have been in the previous mail I tried to send
about this which got lost somewhere between maillist-servers... gcc version
was in the subject line, though :-)
amd64, gentoo linux, gcc3.4.
Well, anyway, builds fine now. Thanks for the hack.
Cheers,
Vincent.
> HTH
> Norman
Vincent Schut
SarVision B.V.
Wageningen, The Netherlands
www.sarvision.com
