[Gdal-dev] Connect to Postgre?
Chapman, Martin
MChapman at sanz.com
Fri Jun 25 19:07:14 EDT 2004
Tyler,
I tried that but it doesn't recognize pg as a driver:
C:\gdal\ogr>ogrinfo "PG:dbname=ew host=172.17.38.86"
FAILURE:
Unable to open datasource `PG:dbname=ew host=172.17.38.86' with the
following drivers.
-> ESRI Shapefile
-> UK .NTF
-> SDTS
-> TIGER
-> IHO S-57 (ENC)
-> MapInfo File
-> DGN
-> GML
-> AVCBin
-> REC
-> Memory
I am using Windows 2000 server and VC++ (latest version). I use GDAL
and OGR a lot, so I know the libs work. I think that the PG support is
not enabled in my build. How do I enable the build to turn on support
for PG? By the way, I actually have my app on both Linux Redhat 9 and
Windows, so instructions on how to enable it on both, or either, is
fine.
Thanks for the help.
Martin
-----Original Message-----
From: Tyler Mitchell [mailto:tjmitchell at riverside.bc.ca]
Sent: Friday, June 25, 2004 4:59 PM
To: Chapman, Martin
Cc: gdal-dev at remotesensing.org
Subject: Re: [Gdal-dev] Connect to Postgre?
Hi Martin,
It is quite often already enabled. I'd try using one of the command
line
utilities first to ensure it works. I.e.:
> ogrinfo "PG:dbname=mydatabase host=giserver"
That should give you a list of layers (tables) in the db.
What language are you programming in?
Tyler
gdal-dev-bounces at xserve.flids.com wrote on 06/25/2004 01:58:44 PM:
> All,
> How do I connect to a Postgre database using OGR? In other words,
> how do I put together my connection string to pass to
> OGRSFDriverRegistrar::Open()? I tried the following:
> OGRSFDriverRegistrar::Open("PG:pghost=172.17.38.85;pguser=pbarker;
> pgpass=pbarker;dbname=ew", 0);
> but it returns a NULL dataset. Does anyone know what I'm doing
> wrong? Is Postgre support enabled in the GDAL build automatically?
> Thanks,
> Martin Chapman
> Cell 303-885-1936
> Office 303-660-3933 x226
> mchapman at sanz.com
> http://www.sanz.com
> Gdal-dev mailing list
> Gdal-dev at xserve.flids.com
> http://xserve.flids.com/mailman/listinfo/gdal-dev
