[Gdal-dev] reprojecting 2.0
Paul Kelly paul-grass at stjohnspoint.co.uk
Sat Jun 26 11:35:19 EDT 2004
Hello Maciek
On Sat, 26 Jun 2004, Maciek Sieczka wrote:
> in the another system. Is it now possible to derive exactly the original
> raster A from the raster B back, or, if not, how do I proceed to derive it
> back possibly unchanged?
I would say the short answer is you can't, because re-projecting involves
resampling the raster and you will lose information through interpolation
(or shifting pixel centroids if using nearest neighbour resampling). The
GRASS r.proj man page has quite a good explanation of this:
http://www.geog.uni-hannover.de/grass/gdp/html_grass5/html/r.proj.html
Maybe to give yourself more control over the process convert the raster
into sites (GRASS r.to.sites) before re-projecting and then use your
preferred interpolation method (appropriate for your data) to create your
new raster from the re-projected sites.
Doing this in GRASS gives you more control over
the process but forces you to think in detail about what you are doing,
whilst gdalwarp is very good if you want the job done quickly without
having to think too much about it (or if you already understand the
algorithms it uses and know they are appropriate for your purpose).
Paul
