[Gdal-dev] GDAL: projection data not copying completely
Kyler Laird
Kyler at Lairds.com
Wed Jun 30 15:40:53 EDT 2004
It's been reported that GeoTIFF images I create using GDAL are unusable
by some applications.
http://groups.google.com/groups?selm=5foEc.18210%24Pc.11314%40fe1.texas.rr.com
The issue seems to be projection data. As a test, I tried to create a
new GeoTIFF from an existing one, using the existing image's projection
data.
a = gdal.Open('/tmp/a.tif')
b = gdal.GetDriverByName('GTiff').Create(
'/tmp/b.tif',
a.RasterXSize, a.RasterYSize,
3, gdal.GDT_Byte,
[ 'TILED=YES' ]
b.SetDescription(a.GetDescription())
b.SetProjection(a.GetProjection())
b.SetGeoTransform(a.GetGeoTransform())
b.SetMetadata(a.GetMetadata())
Performing a diff on the output of listgeo for each of these images, I
see the culprit(s).
< ProjNatOriginLongGeoKey (Double,1): -89
< ProjFalseOriginLongGeoKey (Double,1): 0
> ProjFalseEastingGeoKey (Double,1): 0
> ProjFalseNorthingGeoKey (Double,1): 0
> ProjFalseOriginLongGeoKey (Double,1): -89
< ProjFalseOriginEastingGeoKey (Double,1): 0
< ProjFalseOriginNorthingGeoKey (Double,1): 0
Any ideas on how to get GDAL to fully copy the existing settings?
Thank you.
--kyler
