[Gdal-dev] GDAL 1.2.0 Beta Release - Error
Lorenzo Moretti
lorenzo.moretti at bologna.enea.it
Thu Mar 4 05:36:17 EST 2004
>Lorenzo,
>As a convenience someone changed r.in.gdal to use band names derived
>from the apparent photometric interpretation. I believe the photometric
>interpretation improved between GDAL 1.1.8 and 1.1.9 which is why
>changing gets the altered names.
>>and I must change the name of 2 files.
>>I read the QuickBird specification and the bands are blue, green, red.
>But what does it say in the TIFF file? It doesn't really matter what it
>says in the quickbird specficiation if they produce confusing TIFF files.
>What is the "tiffinfo" report for the files in question?
>Best regards,
Frank
From tiffinfo (from libtiff)
[lor:/] lor% /usr/local/grasslib/bin/tiffinfo
/Volumes/ESTERNO/cartografia/file_esterni/QB/PALE/PAN+MS/scena_destra/03MAY19095313-M2AS_R1C1-000000040462_01_P002.TIF
TIFFReadDirectory: Warning,
/Volumes/ESTERNO/cartografia/file_esterni/QB/PALE/PAN+MS/scena_destra/03MAY19095313-M2AS_R1C1-000000040462_01_P002.TIF:
unknown field with tag 33550 (0x830e) encountered.
unknown field with tag 33922 (0x8482) encountered.
unknown field with tag 34735 (0x87af) encountered.
unknown field with tag 34736 (0x87b0) encountered.
unknown field with tag 34737 (0x87b1) encountered.
TIFF Directory at offset 0x2000018
Image Width: 2048 Image Length: 2048
Bits/Sample: 16
Sample Format: unsigned integer
Compression Scheme: None
Photometric Interpretation: RGB color
Extra Samples: 1<unspecified>
Date & Time: "2003:05:29 03:22:32"
Copyright: "(C) COPYRIGHT 2002 EarthWatch Incorporated, Longmont CO
USA 80501-6700"
Image Description: "{\n bandList = \n [\n 1;\n 2;\n
3;\n 4;\n ]\n}"
Orientation: row 0 top, col 0 lhs
Samples/Pixel: 4
Rows/Strip: 256
Min Sample Value: 0
Max Sample Value: 2006
Planar Configuration: separate image planes
[lor:/] lor%
From .IMD file (image meta data file) of my .TIF file of QUICBIRD I have:
version = "N";
generationTime = 2003-05-29T03:23:37.000000Z;
productOrderId = "000000040462_01_P002";
imageDescriptor = "Standard2A";
bandId = "Multi";
panSharpenAlgorithm = "None";
numRows = 5955;
numColumns = 5943;
productLevel = "LV2A";
radiometricLevel = "Corrected";
bitsPerPixel = 16;
compressionType = "None";
BEGIN_GROUP = BAND_B
ULLon = 12.74969287;
ULLat = 43.05077675;
ULHAE = 0.00;
URLon = 12.95384508;
URLat = 43.05461067;
URHAE = 0.00;
LRLon = 12.95881598;
LRLat = 42.90458014;
LRHAE = 0.00;
LLLon = 12.75515876;
LLLat = 42.90076616;
LLHAE = 0.00;
absCalFactor = 1.431000e-02;
END_GROUP = BAND_B;
BEGIN_GROUP = BAND_G
ULHAE = 0.00;
URHAE = 0.00;
LRHAE = 0.00;
LLHAE = 0.00;
absCalFactor = 1.045000e-02;
END_GROUP = BAND_G;
BEGIN_GROUP = BAND_R
ULHAE = 0.00;
URHAE = 0.00;
LRHAE = 0.00;
LLHAE = 0.00;
absCalFactor = 9.680000e-03;
END_GROUP = BAND_R;
BEGIN_GROUP = BAND_N
ULHAE = 0.00;
URHAE = 0.00;
LRHAE = 0.00;
LLHAE = 0.00;
absCalFactor = 1.568000e-02;
END_GROUP = BAND_N;
outputFormat = "GeoTIFF";
BEGIN_GROUP = IMAGE_1
satId = "QB02";
CatId = "1010010001E96F02";
SceneID = "2";
collectedRowGSD = 2.545;
collectedColGSD = 2.517;
meanCollectedGSD = 2.531;
rowUncertainty = 623.81;
colUncertainty = 113.51;
sunAz = 141.197;
sunEl = 62.4302;
satAz = 170.133;
satEl = 77.3454;
inTrackViewAngle = -10.9489;
crossTrackViewAngle = 3.93044;
offNadirViewAngle = 11.5137;
autoCloudCover = 0.04;
manualCloudCover = 0.1125;
PNIIRS = 2.8;
imageQuality = "Excellent";
TDILevel = 13;
positionKnowledgeSrc = "R";
attitudeKnowledgeSrc = "R";
revNumber = 8888;
END_GROUP = IMAGE_1;
BEGIN_GROUP = MAP_PROJECTED_PRODUCT
earliestAcqTime = 2003-05-19T09:53:13.207882Z;
latestAcqTime = 2003-05-19T09:53:13.207882Z;
datumName = "WE";
semiMajorAxis = 6378137.0000;
inverseFlattening = 298.257223563;
datumOffset = (
0.000,
0.000,
0.000 );
mapProjName = "UTM";
mapProjCode = 1;
mapZone = 33;
mapHemi = "N";
mapProjParam = (
0.000000000,
0.000000000,
0.000000000,
0.000000000,
0.000000000,
0.000000000,
0.000000000,
0.000000000,
0.000000000,
0.000000000,
0.000000000,
0.000000000,
0.000000000,
0.000000000,
0.000000000 );
productUnits = "M";
originX = 316728.99995154;
originY = 4768910.99999898;
orientationAngle = 0.0;
resamplingKernel = "NN";
productGSD = 2.80;
colSpacing = 2.80;
rowSpacing = 2.80;
ULX = 316728.99995154;
ULY = 4768910.99999898;
ULH = 0.00;
URX = 333366.59997505;
URY = 4768910.99999922;
URH = 0.00;
LRX = 333366.59997550;
LRY = 4752239.79999924;
LRH = 0.00;
LLX = 316728.99995242;
LLY = 4752239.79999899;
LLH = 0.00;
DEMCorrection = "none";
numGCP = 0;
END_GROUP = MAP_PROJECTED_PRODUCT
END;
YOU see the bands:
1st band is BAND_B (BLUE)
2nd band is BAND_G (GREEN)
3th band is BAND_R (RED)
4th band is BAND_N (NEAR IR)
Quick Bird has this format but gdal and grass read only .TIF files
without reading .IMD file.
The BAND_B for gdal is BAND_RED and BAND_R is BAND_BLUE. This is wrong
________________________________________________________________________
|| Lorenzo Moretti e-mail: lorenzo.moretti at bologna.enea.it
||/|/| ENEA prot Web: http://wwwamb.bologna.enea.it/
|| | via Don Fiammelli, 2 FTP: ftp://ftpamb.bologna.enea.it/ (ris.)
~~~~~~ 40128 BOLOGNA - ITALY Ph: +39-0516098086 Fax: +39-0516098131
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20040304/95a5d24c/attachment.html
