[Gdal-dev] EPSG 6.5 and extended Dictionary lookups
Derrick J Brashear
shadow at dementia.org
Mon Mar 8 17:32:15 EST 2004
On Fri, 5 Mar 2004, Frank Warmerdam wrote:
> Folks,
> As part of the GDAL 1.2.0 release I updated to EPSG 6.5 coordinate systems.
> That should be in the beta snapshot.
> I have also (in CVS) added support for reading coordinate system dicionaries.
> This mechanism basically allows coordinate system codes to be looked up in
> a text file (from the GDAL data directory), where the code is corresponded
> to a WKT representation of the coordinate system.
would it be worthwhile to provide a way to compile these in like the rest
of the epsg tables can be (at compile time, of course)?
actually, i assume not.
