[Gdal-dev] Re: VC7 build log
Frank Warmerdam
warmerdam at pobox.com
Wed Mar 10 13:27:06 EST 2004
Roger (or others),
\Vterrain\APIs\gdal\alg\gdalwarpoperation.cpp(637) : warning C4312:
'type cast' : conversion from 'long' to 'void *' of greater size
This code looks like:
((void **) pThreadData)[2] = (void *) (long) eErr;
Given that I want to convert an enumerated error code into a pointer is
there any more "proper" way of doing it than this?
> \Vterrain\APIs\gdal\frmts\envisat\envisatdataset.cpp(546) : warning
> C4267: '=' : conversion from 'size_t' to 'int', possible loss of data
Ahh yes, all these. Very annoying. I have generally used "int" as
equivelent to size_t and it is warning every time there is a cast back
or forth. This does not cause a complain under gcc -Wall and I am not
inclined to make a comprehensive pass through fixing it at this time.
I would note that a non-trivial number of the warnings are in libpng, libjpeg,
and libz which I don't have any influence over. If I fix the copy in GDAL
then the changes will just be lost on my next upgrade.
> The problem is that at some point the size_t typedef on windows became
> an unsigned int. I think it is something to do with 64 bit
> compatability. C4267 is definitely a very bad warning to disable. I for
> one am very much in the "every warning masks a potential error" camp. I
> have mailed you a build log separately.
Death to C4267! Err, I mean, I give up on it for now.
Re: file.lst files:
> Not that I am aware of but maybe somebody else knows.I do not think it
> would be beyond possibility (but beyond my own knowledge and timetable)
> to make a perl script to edit the vcproj files. However, I am happy to
> keep the files reasonably up to date and send you updates. My comments
> on not wanting responsibility were of the legalistic nature seeing as
> the files did not have any disclaimer associated with them. I did not
> mean to wash my hands of them completely.
Well, I am not keen on update scripts. I will commit the project files
to CVS, and I would be happy to offer you CVS commit access if you would
like to update them (and even fix warnings carefully).
Also, please don't mind my crankiness too much. I am having a frustrating
time keeping on top of actual paying work as well as the many requests for
help, bug fixes and so forth on my many libraries. My days often have a
peak frustration around noon, when I am pretty much dug out of overnight
requests for help, and ready to start on real work. Less than half the
requests for help I get come via public mailing lists where others can help
out, and of course there are a number of other projects I am involved beside
GDAL itself.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
