[Gdal-dev] Re: VC7 build log
Roger James roger at beardandsandals.co.uk
Wed Mar 10 14:10:11 EST 2004
Wonderful,
Now that's the kind of fix I like.
Thanks Martin.
Roger
> Here's what MS says (below).  I don't think turning the compiler
warning
> off is a big deal if you don't need 64bit compatibility. Just turn off
> the /WP64 switch or use a pragma on the warning.  It's only a
> compatibility warning....right?  Are you using 64bit?
