[Gdal-dev] GDAL 1.2.0 Solaris build
Frédéric Trastour
support at geoimage.fr
Thu Mar 11 08:52:00 EST 2004
Hello,
I have tested the configure script generated by autoconf (v 2.59) from the modified configure.in
( with unset ) and it worked fine ( proj library detected in the second alternate location ) on my
solaris 2.7 system.
Do you will add ( Andrey ) the change to the configure.in script in cvs ?
ps : I have just a little doubt on the portablity of the 'unset' shell command : some parts of the
script use '$as_unset' instead of 'unset' but some other parts use 'unset' directly.
Frédéric
----- Original Message -----
To: <gdal-dev at remotesensing.org>
Sent: Thursday, March 11, 2004 12:13 PM
Subject: Re: [Gdal-dev] GDAL 1.2.0 Solaris build
> Hello,
> I think there is a simple solution to the caching problem of AC_CHECK_LIB.
> I have tested this solution with a modified configure script and it worked for me.
> Here is a proposed change to configure.in ( not tested as I can't generate configure
> from configure.in, but I hope to be able to do it today ) :
> __________________________________________________________________________________________
> dnl ---------------------------------------------------------------------------
> dnl PROJ.4 related stuff.
> AC_MSG_CHECKING([how to link PROJ.4 library])
> AC_ARG_WITH(static_proj4,[ --with-static-proj4=ARG Compile with PROJ.4 statically (ARG=no or path)],,)
> if test "x$with_static_proj4" = "xno" -o "x$with_static_proj4" = "x"; then
> PROJ_STATIC=no
> AC_MSG_RESULT([link dynamically.])
> else
> PROJ_STATIC=yes
> AC_MSG_RESULT([link statically.])
> ORIG_LIBS="$LIBS"
> PROJ_LIB="-lproj"
> if test "x$with_static_proj4" = "xyes" ; then
> LIBS="$PROJ_LIB $ORIG_LIBS"
> AC_CHECK_LIB(proj,pj_init,PROJ_STATIC=yes,PROJ_STATIC=no,)
> else
> LIBS="-L$with_static_proj4/src $PROJ_LIB $ORIG_LIBS"
> if test "$PROJ_STATIC" = "no"; then
> dnl Disable previous value cached by the previous AC_CHECK_LIB test :
> dnl AC_CHECK_LIB caches the result value for a couple (function, library)
> dnl in a variable named "ac_cv_lib_<library name>_<function name>".
> dnl In order to try to locate the library in different locations, using
> dnl different values of LIBS, we have to 'unset' this variable after
> dnl each negative test.
> unset ac_cv_lib_proj_pj_init
> LIBS="-L$with_static_proj4/lib $PROJ_LIB $ORIG_LIBS"
> fi
> LIBS="-L$with_static_proj4/src/.libs $PROJ_LIB $ORIG_LIBS"
> fi
> LIBS="-L$with_static_proj4 $PROJ_LIB $ORIG_LIBS"
> fi
> fi
> fi
> LIBS="$ORIG_LIBS"
> fi
> if test -r "$with_static_proj4/src/proj_api.h" ; then
> PROJ_INCLUDE="-I$with_static_proj4/src"
> elif test -r "$with_static_proj4/include/proj_api.h" ; then
> PROJ_INCLUDE="-I$with_static_proj4/include"
> elif test -r "$with_static_proj4/proj_api.h" ; then
> PROJ_INCLUDE="-I$with_static_proj4"
> fi
> fi
> AC_SUBST(PROJ_STATIC)
> AC_SUBST(PROJ_INCLUDE)
> _________________________________________________________________________________________________________
> Regards,
> Frédéric.
> From: "Andrey Kiselev" <dron at ak4719.spb.edu>
> Sent: Wednesday, March 10, 2004 6:32 PM
> > On Wed, Mar 10, 2004 at 01:23:43PM +0100, Fr?d?ric Trastour wrote:
> > > The problem is that when the first test fails, the result is "cached"
> > > - in a variable - and the others tests are not done.
> > > Perhaps there is a simple way to disable the caching mecanism used by
> > > AC_CHECK_LIB ?
> > There is an attempt to disable caching at the start of the configure.in
> > script... seems it don't work for you. Autoconf manual contains the
> > following section, where described, how to disable cahcing. Could you
> > try whether the using .autom4te.cfg file in the GDAL root directory
> > helps you? If so I shall add that file to the repository.
> > Customizing `autom4te'
> > One can customize `autom4te' via `~/.autom4te.cfg' (i.e., as found in
> > the user home directory), and `./.autom4te.cfg' (i.e., as found in the
> > directory from which `autom4te' is run). The order is first reading
> > `autom4te.cfg', then `~/.autom4te.cfg', then `./.autom4te.cfg', and
> > finally the command line arguments.
> > In these text files, comments are introduced with `#', and empty
> > lines are ignored. Customization is performed on a per-language basis,
> > wrapped in between a `begin-language: "LANGUAGE"', `end-language:
> > "LANGUAGE"' pair.
> > Customizing a language stands for appending options (*note autom4te
> > Invocation::) to the current definition of the language. Options, and
> > more generally arguments, are introduced by `args: ARGUMENTS'. You may
> > use the traditional shell syntax to quote the ARGUMENTS.
> > As an example, to disable Autoconf caches (`autom4te.cache')
> > globally, include the following lines in `~/.autom4te.cfg':
> > ## User Preferences. ##
> > begin-language: "Autoconf"
> > args: --no-cache
> > end-language: "Autoconf"
> > Andrey V. Kiselev
> > Home phone: +7 812 5274898 ICQ# 26871517
> > Gdal-dev mailing list
> > Gdal-dev at remotesensing.org
> > http://remotesensing.org/mailman/listinfo/gdal-dev
