[Gdal-dev] optimum overview settings?
Chapman, Martin MChapman at sanz.com
Fri Mar 12 17:24:56 EST 2004
Frank,
I will try.
Martin
-----Original Message-----
From: Frank Warmerdam [mailto:warmerdam at pobox.com]
Sent: Friday, March 12, 2004 2:46 PM
To: gdal-dev at remotesensing.org
Subject: Re: [Gdal-dev] optimum overview settings?
Chapman, Martin wrote:
> The new pyramids just got added to the end of the file...so if you had
> an ovr file with 2, 4, 8, and you generated a new levels 2, 4, 8, 16
> ... You would end up with a file of overviews like 2, 4, 8, 2, 4, 8,
> 16.
Martin,
Hmm, that isn't supposed to happen.  I just tried this with a small file
and had no problem:
gdaladdo utm.tif 2 4
gdalinfo utm.tif
Band 1 Block=512x16 Type=Byte, ColorInterp=Gray
   Overviews: 256x256, 128x128
I also verified with tiffinfo that there were no extra overviews
created.
I then did a test with a .bt file that uses external overviews and
things seemed to work fine with it.
So, if you can reproduce the error you mention with 1.2.0 then please
report via bugzilla and I will look into it.
Best regards,
I set the clouds in motion - turn up   | Frank Warmerdam,
Gdal-dev mailing list
Gdal-dev at remotesensing.org
http://remotesensing.org/mailman/listinfo/gdal-dev
