[SPAM] - RE: [SPAM] - RE: [Gdal-dev] Bathymetry data... - Email found in subject - Email found in subject
IMD Listuser imd_listuser at comcast.net
Thu Mar 25 06:28:54 EST 2004
One more question:
-How do I know when I have netcdf support? Do I use the --versions
argument to gdal_translate (as I thought)?
Reason I ask is that I did just rebuild gdal with the netcdf libraries
(uncommented in the nmake.opt file) but I still see no change in the
list titled: 'The following format drivers are configured and support
output:'
TIA
Charlie
Charlie Van Dusen
charlie at im-design.net
-----Original Message-----
[mailto:gdal-dev-admin at remotesensing.org] On Behalf Of Norman Vine
Sent: Wednesday, March 24, 2004 10:11 PM
To: gdal-dev at remotesensing.org
Subject: [SPAM] - RE: [SPAM] - RE: [Gdal-dev] Bathymetry data... - Email
MD Listuser writes:
> Which format does img2latlongrd.c produce? Netcdf?
> I don't believe that gdal_translate supports netcdf? Does it?
> Im running a recent version of gdal. Here is some output:
> GDAL 1.1.9.0, released 2003/06/27
You will need to update your GDAL installation and probably explicitly
configure the netcdf support
HTH
Norman
Gdal-dev mailing list
Gdal-dev at remotesensing.org
http://remotesensing.org/mailman/listinfo/gdal-dev
