[Gdal-dev] Bathymetry data...
Frank Warmerdam
warmerdam at pobox.com
Thu Mar 25 10:03:19 EST 2004
Frank Warmerdam wrote:
> So, I think the easiest thing would just be to write a .aux file for this.
> Likely something like:
> --- start of topo_8.2.aux ---
> AuxilaryTarget: topo_8.2.img
> RawDefinition: 10800 6336 1
> ChanDefinition-1: 16U 0 2 21600 Unswapped
> --- end of .aux file ---
> I found the projection information kind of confusing, so I didn't try to
> replicate that.
Folks,
Following up my own post, I found the data is actually signed so you need to
use 16S instead of 16U for the data type. Also, I added the map information
and it seems to sort of work. Not sure if it is accurate though.
ChanDefinition-1: 16S 0 2 21600 Unswapped
UpLeftX: 0
UpLeftY: 72.006
LoRightX: 360
LoRightY: -72.006
MapUnits: LAT D000
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
