[Gdal-dev] Transforming geographic coords from 0_360 to -180_180?
IMD Listuser imd_listuser at comcast.net
Thu Mar 25 12:06:30 EST 2004
Greesting again list
I was able to use gdal_translate to create a GeoTIFF once I recompiled
gdal with the support for netCDF and the recently updated nmake.opt and
makefile(s). Thanks to Norman and Frank ;)
Now I have follow-on question(s)
-Is it possible to control the color depth of the output geotiff using
gdal_translate. I am not able to open the file in photoshop. The error
it throws is something like unsupported color depth.
-Can gdal_translate produce a world file along with the geotiff?
-The original bounds of the netCDF data are expressed in decimal degrees
from 0 to 360. What is the best way for me to convert to standard
hemispheric decimal degrees (-180 to 0 then 0 to 180)?
TIA
Charlie
Charlie Van Dusen
IM Design
charlie at im-design.net
+1 781.389.0343
