[Gdal-dev] Re: GDAL with HDF on OSX
Lorenzo Moretti
lorenzo.moretti at bologna.enea.it
Fri Mar 26 07:35:12 EST 2004
I have GDAL 1.2.0 for OS X built with HDF 4.2r0 support in my GRASS
LIBRARIES for OS X version (see below for site)
This version is built from HDF version in
ftp://ftp.ncsa.uiuc.edu/HDF/HDF/HDF4.2r0/bin/macosx
Grass does not import HDF directly from r.in.gdal but you have to
convert to tif with GDAL. (Is it true Andrey ?)
From my Grass_Libraries
Importing ASTER Level1A and B (HDF files)
HDF version 5 is incompatible with HDF version 4. Aster Level 1A and
Level 1B are in HDF-EOS format (version 4 of HDF library).
You must convert HDF files in GeoTiff for importing HDF in other
programs like GRASS. Now it's impossible to import directly HDF.
You must use gdalwarp utility.This is the method:
[lor:~] lor% /usr/local/grasslib/bin/gdalwarp -t_srs
'projection_of_output' name_of_subdataset_of_hdf name_of_output_file
In this example I convert HDF files to geotiff file in utm zone 33 projection.
Open Terminal and enter
[lor:~] lor% /usr/local/grasslib/bin/gdalwarp -t_srs '+proj=utm
+zone=33 +datum=WGS84'
HDF4_SDS:ASTER_L1B:"/file_ASTER/AST_L1B_003_01102002101254_05222002150244.hdf":2
/aster_tif/aster1.tif
.... and so on for all subdataset.
One geotiff file for any subdatasets: in Aster level_1B I have 15 Geotiff files
Some new HDF files have new szip compression
Bye
________________________________________________________________________
|| Lorenzo Moretti e-mail: lorenzo.moretti at bologna.enea.it
||/|/| ENEA prot/idr Web: http://wwwamb.bologna.enea.it/
|| | via Don Fiammelli, 2 FTP: ftp://ftpamb.bologna.enea.it/ (res.)
~~~~~~ 40128 BOLOGNA - ITALY Ph: +39-0516098086 Fax: +39-0516098131
Download GRASS for MAC OS X:
http://wwwamb.bologna.enea.it/forgrass/
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20040326/d818b5bc/attachment.html
