[Gdal-dev] Re: GDAL with HDF on OSX
Andrey Kiselev
dron at ak4719.spb.edu
Fri Mar 26 09:55:06 EST 2004
On Fri, Mar 26, 2004 at 03:32:40PM +0100, Lorenzo Moretti wrote:
> I have enter in r.in.gdal box (GIS file input) subdataset file:
> HDF4_SDS:ASTER_L1B:"/file_ASTER//AST_L1B_003_01102002101254_05222002150244.hdf":2
> but I have this error in output:
> ERROR: Input map is rotated - cannot import. You may use 'gdalwarp' to
> transform the map to North-up.
> This error does not permit me to import HDF file into GRASS but I
> must use gdalwarp in terminal.
Ah, yes, r.in.gdal wants rotated dataset. Then your approach is right,
you should process the input dataset with gdalwarp. But remember, this
is valid for that particular data type only, not for HDF files in
general.
Andrey
Andrey V. Kiselev
Home phone: +7 812 5274898 ICQ# 26871517
