[Gdal-dev] User Question: creating a geotiff from pnm
Frank Warmerdam
warmerdam at pobox.com
Fri Mar 26 16:19:13 EST 2004
Michael Darweesh wrote:
> Thanks for the quick reply, Frank.
> It sounds like I'm thinking about this the wrong way. Perhaps I should
> just try gdal_translate and see if that meets my needs before I go
> writing a specialized solution. Then, if it's too slow or not producing
> what I want, then we should talk further. Does that sound sane?
Michael,
Yes.
> Also, the gdal_translate.c I was typing about was the one on
> http://www.remotesensing.org/gdal/gdal_translate.c.html, not the one in
> the tarball. just maybe a broken link on the website.
Ahh, I see. The examples documentation has been broken in this regard
for a while I think. I have removed the gdal_translate from the set of
example code. It is far to complex as a simple writing example
anyways.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
