[Gdal-dev] Re: OGR C API question
Stephan Holl
sholl at gmx.net
Mon Mar 29 10:44:07 EST 2004
On Mon, 22 Mar 2004 23:38:46 +0100
Markus Neteler <neteler at itc.it> wrote:
> On Mon, Mar 22, 2004 at 09:53:21AM -0500, Frank Warmerdam wrote:
> > Markus Neteler wrote:
> > > poSpatialFilter = OGR_G_CreateGeometry( wkbPolygon );
> > > Ogr_oRing = OGR_G_CreateGeometry( wkbLineString );
> > > OGR_G_AddPoint(Ogr_oRing, xmin, ymin, 0);
> > > OGR_G_AddPoint(Ogr_oRing, xmin, ymax, 0);
> > > OGR_G_AddPoint(Ogr_oRing, xmax, ymax, 0);
> > > OGR_G_AddPoint(Ogr_oRing, xmax, ymin, 0);
> > > OGR_G_AddGeometryDirectly(poSpatialFilter, Ogr_oRing);
> > > OGR_L_SetSpatialFilter(Ogr_layer, poSpatialFilter );
> > >Does anyone see why this doesn't work any longer? The spatial
> > >filter is simply ignored.
> > Markus,
> > The wkbLineString should be wkbLinearRing. It looks like the
> > AddGeometryDirectly() method returns
> > OGRERR_UNSUPPORTED_GEOMETRY_TYPE if you pass anything other than a
> > wkbLinearRing to add to a polygon. The checking may have been
> > added after the initial implementation though I see nothing obvious
> > in the change logs.
> Great, now it works smoothly (tried with SHAPE, hope it does as well
> with PostGIS data).
After some testin it does not work with PostGIS-data. It always pulls
the whole geometries out of PostGIS.
Does anybody know a solution?!
Thanks
Stephan Holl
Check headers for GnuPG Key!
