[Gdal-dev] gdal on amd64 needs -fPIC?
Vincent Schut
schut at sarvision.com
Tue Mar 30 05:50:17 EST 2004
I just tried to compile gdal on my new amd64. It complained about needing
-fPIC in the final install phase (where all libs are archived together into
one I think). After I recompiled netcdf and hdf4 with -fPIC, I tried to
compile gdal with -fPIC and then it compiled fine. To do this, I both changed
GDALmake.opt and libtool.
I will investigate some more, e.g. do only hdf/netcdf need -fPIC or also GDAL
(this seemed to be the case, but I'm not yet sure).
Does it sound likely that gdal needs -fPIC on amd64? I really need to check
out what this -fPIC thing does...
Frank and other developers, your comments please...?
If you need some amd64 testing, please inform me.
Cheers,
Vincent Schut
SarVision B.V.
Wageningen, The Netherlands
www.sarvision.com
