[Gdal-dev] Experiences compiling gdal-1.2.0 w/ JP2KAK Support
Alessandro Amici alexamici at fastwebnet.it
Mon May 3 04:19:49 EDT 2004
Valentine, Frank,
On Friday 30 April 2004 21:30, Valentine Anantharaj wrote:
> The make process quit while trying to link 'libgdal.so'.  Then I had to
> hack the GDALmake.opt to explicitly specify a path to the location of
> '-lkdu'.  But when I did this, libtool started re-making some of the
> sources on ogr/ and quit complaining about unresolved references to JP2K
> functions in 'libgdal.so'.  So, I reconfigure by including
> '--without-libtool'.  Now, it compiled file (I still had to re-hack
> GDALMake.opt though).
the kakadu driver is not supported by the normal (libtool) build (i lack a
testing environment), Frank this should probably be documented somewhere.
cheers,
alessandro
