[Gdal-dev] GTOPO30 problem
Frank Warmerdam
warmerdam at pobox.com
Thu May 6 16:18:31 EDT 2004
Clay, Bruce wrote:
> Frank:
> Thanks for the update. After nearly a week of debugging and pulling
> my hair out (what little is left that is), I think I found the problem.
> It appears to be in the least likely of all places, Winzip. All of the
> GTOPO30 files are tarred and gzipped. I have been using Winzip to
> unpack the files and that appears to be the mistake. MicroDem has the
> ability to uncompress and untar files. When I used MicroDem to unpack
> the files I get the correct min and max values as defined in the GTOPO30
> document (at least for the file in question). As a sanity check I went
> back to Winzip and checked the files out of the same compressed data
> file the run the latest gdalinfo I get
> "Computed Min/Max=-32768.000,32767.000"
> I can't explain why this is the case just that it certainly appears to
> be. I would be real happy to have independent confirmation from anyone
> that has the time to run the same test "gdalinfo -mm e020n90.dem" on a
> dem file extracted with Winzip version 8.1
> Another interesting tidbit I just tried is a freeware program
> (PowerArchiver 2001, v6.1) unpacks the data correctly such that the
> results of the above test are "Computed Min/Max=-137.000,5483.000"
Bruce,
I hope I never meet a WinZip developer. They provide a "convenient default
option" to apply DOS/UNIX CR/LF conversion when unpacking files. Unfortunately
this corrupts binary files. I have had no end of hassles due to this brain
dead decision on their part.
We used to run into a similar problem with people downloading files by ftp
and the ftp client applying default CRLF conversion.
Damn, and double damn winzip.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
