[Gdal-dev] Fusion tool bug fix
Mario Beauchamp
starged at videotron.ca
Fri May 7 16:26:01 EDT 2004
Hi again,
I corrected a bug that was overwriting the geotransform of the source panchromatic image. Python
programmers will immediately see that rookie mistake in the compute() method :)
But it made me realize something: it's possible then to modify the georeferencing of an image
without rewriting the whole file, is it not? However, when I tried to correct the 2 files that were
modified this way (ie with SetGeoTransform), it did not work. I will investigate that further
because this feature may be very useful to correct wrongly georeferenced images.
Sorry for the inconveniences, if any...
Mario B.
My Landsat images:
http://pages.infinit.net/starged/landsat/home.html
