[Gdal-dev] Problems Linking with Stubs in the precompiled downloadable Win32 Binaries.
Chapman, Martin MChapman at sanz.com
Mon May 10 18:32:12 EDT 2004
Louis,
Try using the build instructions (Windows) from the command line at
http://www.remotesensing.org/gdal/gdal_building.html first.  You don't
need to use the VC++ IDE.  Just the compiler from the command line works
great every time for me.  I wouldn't use the IDE, to much other stuff
needed that isn't nessesary from the command line.  Let me know if that
works.  Then I will show you how to link the gdal_i.lib to you
application in the VC++ IDE.
Martin
-----Original Message-----
Sent: Monday, May 10, 2004 3:29 PM
To: gdal-dev at remotesensing.org
Subject: RE: [Gdal-dev] Problems Linking with Stubs in the precompiled
Martin,
Could my problem be that I'm using VC6? I tried compiling from scratch
and the MSVCRT lib was hassling me all the way to suicidal depression.
VC7 would be hard for me to acquire tho...
Louis.
[mailto:gdal-dev-admin at remotesensing.org]On Behalf Of Chapman, Martin
Sent: 10 May 2004 11:15
Louis,
The windows version of gdal is awesome. Never had a problem that wasn't
created by me, and our apps make heavy use of GDAL and OGR.  I usually
download the daily .zip and build it using VC7 .Net from the command
line.  There are build instructions on the gdal website for windows that
are complete and easy to follow.
Martin
Sent: Monday, May 10, 2004 1:29 PM
Subject: [Gdal-dev] Problems Linking with Stubs in the precompiled
I'm quite new to the GDAL world and sofar its gone quite smoothly - but
today I tried using OGR Style Tools and now I'm getting unresolved
symbol errors when linking the libs. Its just looks as tho something was
left out of the precompiled binaries. I'm going to try building the GDAL
package from scratch and see if the stubs the scripts generate solve the
problem. Still, I like doing things the easy way. If someone could
verify the integrity of the pre-compiled Win32 binaries that would be
swell.
Thanks
Louis Pool.
Gdal-dev mailing list
Gdal-dev at remotesensing.org
http://remotesensing.org/mailman/listinfo/gdal-dev
