[Gdal-dev] Problems Linking with Stubs in the precompiled downloadable Win32 Binaries.
Chapman, Martin MChapman at sanz.com
Mon May 10 18:35:55 EDT 2004
Frank and Louis,
I think the problem is Louis is using the IDE to compile the project.
He should just use the makefile from the command line.  That works every
time.
Martin
-----Original Message-----
From: Frank Warmerdam [mailto:warmerdam at pobox.com]
Sent: Monday, May 10, 2004 3:32 PM
To: gdal-dev at remotesensing.org
Subject: Re: [Gdal-dev] Problems Linking with Stubs in the precompiled
Fam. Pool wrote:
> Martin,
> Could my problem be that I'm using VC6? I tried compiling from scratch
> and the MSVCRT lib was hassling me all the way to suicidal depression.
> VC7 would be hard for me to acquire tho...
Louis,
I normally build with VC6 myself.  Unless some specific support library
(like JasPer?) requires VC7 you should be fine with VC6.
Best regards,
I set the clouds in motion - turn up   | Frank Warmerdam,
Gdal-dev mailing list
Gdal-dev at remotesensing.org
http://remotesensing.org/mailman/listinfo/gdal-dev
