[Gdal-dev] jpeg2000 memory management??????
Andrey Kiselev dron at ak4719.spb.edu
Tue May 11 02:20:33 EDT 2004
On Fri, Apr 30, 2004 at 03:07:47PM +0530, Bylahalli  Chandrashekara  Prasad, Noida wrote:
> i am working on JASPERE code looking for memory efficieny, i found  a
> memory leakeage in the code and also a bug in quantization
Does these bug and leakage located in the GDAL JasPer driver or in
JasPer library itself? In latter case you should report the problem to
Michael Adams, author of the library.
Andrey V. Kiselev
Home phone:  +7 812 5274898  ICQ# 26871517
